Author: Subject: Brake bias bar.
ewanspence
posted on 12/3/02 at 10:24 AM Reply With Quote
Brake bias bar.
I am now getting to the stage of my brakes. I am using the standard Sierra master cyliner and servo with Front and rear discs.
The car originally had ABS but got shot of that. What do I need to do to give me the correct front to rear braking forces? It also needs to be SVA friendly - which I think means it must not me adjusted once set (ie on the move).
Ewan.
Visit the MegaGrip site :-
http://www.geocities.com/ewanspence/
bob
posted on 12/3/02 at 02:19 PM Reply With Quote
I am going the same way with brakes as you,i was told by MK who supplied my chassis that with the sierra m/cylinder i would'nt need the bias.
The problem with the bias used on the sierra is that it wont work on the rolling road(SVA test).It will only work on the road as its sort of inertia based,if and when you slam the brakes on a ballbearing in the bias shoots forward decreasing the pressure to rear brakes.
If someone can tell me otherwise i would be gratefull of the info.
theconrodkid
posted on 12/3/02 at 06:25 PM Reply With Quote
Ewan use a fiat panda one,can be made adjustable cheap as well,any probs gis a shout
Simon Mc
posted on 22/5/02 at 09:04 PM Reply With Quote
Conrod, can the panda one be modified as easily as the early mini type?
paulbeyer
posted on 23/5/02 at 09:14 AM Reply With Quote
I've been following a similar thread on the Robin Hood group. Some of the guys on that group have used valves from Fiesta's. Apparently they are non adjustable and don't rely on inertia to reduce the pressure to the back brakes. By all accounts all you need to do is plumb one of these in to the rear brake line and hey presto instant SVA friendly balanced brakes.
theconrodkid
posted on 24/5/02 at 04:05 PM Reply With Quote
The good bit about UNO not panda(sorry ny mistake)valves is they are the same as a mini valve in opperation but have the opperating rod outside so no need to drill holes etc,just fit and make a bracket for an adjusting bolt to push on the opperating rod
so simple even i could do it!
Liam
posted on 24/5/02 at 06:00 PM Reply With Quote
What's the deal with getting balance bar adjustable brakes through an SVA. I have been planning to use a balance bar brake pedal, Tilton for example, and have it fully adjustable (in cockpit) after the SVA.
I've heard some people have got them passed as they are, some people have had to have lock nuts to prevent adjustment, and some people have had to weld the lock nuts on.
Does anybody know the official line?
Liam
Mike McKinstry
posted on 24/5/02 at 07:46 PM Reply With Quote
liam,read my posting "brake deceleration valve" on page 2 of this topic(running gear)-21 responses to view.
spoke to R/Hood guy at stoneleigh and some sva centres have even tried to fail "wired"
Titon---important though- apparantly must not be adj. from cockpit?!
Cheers Mike.
