Cluelesstom
| posted on 3/6/18 at 07:52 PM |
Passing master cylinder, possible upgrade?
Hello guys, master cylinder has just started to pass back into the reservoir, as it was an old Sierra one I’m thinking of using a smaller bore size
Assuming this will give me a better pedal feel? Running escort front end with disk and rear drums, I’m currently looking at a triump dual circuit
With a 17.78mm bore, will this be suitable and what can I expect if I did want to upgrade the brakes in future to say 4 pots?
Thanks!
Cluelesstom
| posted on 3/6/18 at 09:04 PM |
Or maybe a mk1 fiesta 19mm bore?
melly-g
| posted on 3/6/18 at 09:32 PM |
I replaced my Sierra one with the mk1 Fiesta non servo master cylinder.
Best thing I ever did! So much more feel in the brakes now, not like pushing on a solid block of wood!
Don't know how this would be affected by the upgrade though?
Cluelesstom
| posted on 4/6/18 at 08:01 AM |
Hello! , do the mounting holes line up? I assume you needed to modify the pipework which isn’t a problem.
melly-g
| posted on 4/6/18 at 09:54 AM |
I did have to drill new holes they were about 15mm out!
Yes pipe work just needed bending to make good.
I also had to add a bleed nipple on the cylinder to blank off one port that was not needed.
Cluelesstom
| posted on 4/6/18 at 11:34 AM |
Thanks pal, do you know what size fittings they are for the bleed screw?
melly-g
| posted on 4/6/18 at 12:08 PM |
erm no!
The same as a pipe fitting, before fitting it take to a motor factors and ask for a bleed nipple or a blanking plug for whichever one you want to
delete.
Cluelesstom
| posted on 13/6/18 at 07:12 AM |
Hello, got the master cylinder, I’m using a spacer instead of cutting up stuff, and also which outlets for front brakes does it matter?
