jps
| posted on 22/8/18 at 09:02 AM |
Off the shelf handbrake cable?
I have Sierra disc calipers but not the original cable to cut down. Is there anything which is closer to the right size I can use instead?
pewe
| posted on 22/8/18 at 11:18 AM |
IIRC I used one from an Austin Maxi.
Oddball I know but if it works it works....
HTH.
Cheers, Pewe10
big_wasa
| posted on 22/8/18 at 11:59 AM |
I used Austin allegro for drums. No cutting needed.
| posted on 22/8/18 at 12:45 PM |
If you use Austin Maxi of Allegro cables you will need 2
