thelynxeffect
| posted on 9/9/18 at 07:22 PM |
Static ride height question
So amongst other this today I set my static ride height , the only question I have is should I accommodate sag of the driver in the base settings I.e.
Should the rear RHS be set slightly higher than the left to take the driver sag into account? I get about 8mm of sag on the right and about half that
on the left when I climb in.
gremlin1234
| posted on 9/9/18 at 09:33 PM |
you should set ride height (and corner weights...) to as close as 'normal running condition'
ie if just you driving
then weight in just the drivers seat,
but if you will normally have a passenger, weights in both seats
thelynxeffect
| posted on 10/9/18 at 05:08 AM |
What sort of corner (front/rear) weight ratio should I be aiming for? Just road driving.
907
| posted on 10/9/18 at 06:15 AM |
You can only change front to back by moving stuff, i.e. mounting engine further back or forwards.
In reality this can only be done in the design stage.
Might be able to move the battery but thats about it.
The main thing is with corner weighting is to have equal grip on all 4 tyres.
Think of sitting on a dining chair, weight on all 4 legs, this is a correctly set up car.
Now chop 15mm off one leg. Chair now sits with weight on just 2 legs and wobbles.
Paul G
thelynxeffect
| posted on 10/9/18 at 09:54 AM |
But using your analogy, if I were to chop an inch of the front two legs, the CofG of me on the chair would shift forward and thus the weight on the
front legs would be greater. Hence I can adjust front/rear weighting by modifying ride height?
JimSpencer
| posted on 10/9/18 at 10:42 AM |
Theoretically you are correct - but it'd be so marginal as to make little/no noticeable difference.
The weight bias front to rear is determined by the location of the major items in the car - you would move considerably more weight from the rear to
the front my moving your seat forward than by adjusting the ride height at the rear
Back to your original question:-
In short;- Yes the off side rear would normally have a higher static, unloaded, ride height to allow for the driver.
Assuming
The car is set up to be used mainly with just the driver in it.
How much will depend on the corner weight settings, but your measurement giving a 4mm net difference could be possible.
A couple of hints:-
Make sure the car still has some rake in it once you're in it - circa 10mm ish higher at the rear than the front.
Plus
If you haven't got the kit to get the car aligned and corner weighted prior to using it in anger - go to somebody who has, it transforms how
these cars feel to drive.
thelynxeffect
| posted on 10/9/18 at 11:19 AM |
Thanks for the replies guys, all taken on board, we have corner scales at work so i’ll give it a go, also have a wheel alignment rig so will have a
play with that, if all else fails i’ll go to the pros.
[Edited on 10/9/18 by thelynxeffect]
40inches
| posted on 10/9/18 at 12:16 PM |
I used this Exel sheet to do the calculation. https://robrobinette.com/corner_weight.htm
ianhurley20
| posted on 10/9/18 at 04:19 PM |
On my car I set it all up so the gound clearances were as specified. On the road hit the brakes and front left locks first. Increase the preload on
the rear right and try again. Once I got to the right locking I backed off a bit and then it could be either wheel first. Ok this is not computer
corner weighting but it is how I got my car balanced for my weight in the drivers seat. I do have passengers but never push the car as much then so
its fine for me - if you always have two then thats the way to test. - OR - get it set up on some super dooper computer scale things. But then again
this is a Locost forum.
Toys2
| posted on 10/9/18 at 10:32 PM |
Assuming
A couple of hints:-
Plus
That's interesting can you explain the benefits of rake? Thanks in advance
JimSpencer
| posted on 11/9/18 at 08:45 AM |
quote: That's interesting can you explain the benefits of rake? Thanks in advance
Rake is a tricky one to explain in words (easier to demonstrate!) but i'll have a bash..
Firstly there's the practical side of things - Seven's are normally softer sprung at the rear than the front, so you need more suspension
travel at the rear to avoid bottoming out on the bump stops.
But in the main it’s the effect it should have on handling (assuming the car's set-up is in the ballpark)
Rake changes how the car applies its weight to the front and how fast weight transfer happens when we're braking and then turning in.
More rake will increase the static weight on the front and add steering, less rake the opposite - but having rake in the car will significantly
decrease the time it takes to transfer that weight when we brake and try and turn in - or worse still pile into a fast corner with no brake, and just
a lift for example.
So generally speaking, all other things being equal etc etc.. a car that’s nose up will tend to understeer and go from understeer to oversteer quite
suddenly, with some rake in it it’ll be the opposite..
The additional benefit is > set it up so it handles right with some static rake then you should have a car that’s easily adjustable with minimal
inputs.
I.e. – when I was sprinting my Striker, we could alter it from a touch of understeer to a touch of oversteer by adding a millimetre or two to the
rake.
coyoteboy
| posted on 11/9/18 at 12:23 PM |
rake.
I'd be utterly staggered if a mm or two made that much difference!?
JimSpencer
| posted on 11/9/18 at 06:27 PM |
Hi
Surprising in a way isn't it?
But when the car's dialled (and it was, in 2011 I won the Midland Speed champs with it and it's still got a couple of the class records
form then.) it's surprising how small a change you need to get a noticeable difference, not much mind but you could tell the difference..
My brother and I spent a LOT of time getting the setup right
We didn't have the bhp to do it any other way
Toys2
| posted on 11/9/18 at 06:41 PM |
a lift for example.
inputs.
rake.
That's brilliant, thank you for the time taken to explain
I bought a used Striker a couple of years back, the suspension set up "as bought" was from the school of, whack up the damping rate up to
the point that the dampers were very stiff, 'cause a stiff car handles, yeah?
It was skittish and uncomfortable. I softened the rear considerably, the front rate was already near minimum, the car handled so much better. Though
only used on the road
It was only when looking back at some photos, that I realised that the front was about 10-15mm higher than the rear. It's SORNed at the moment,
so I haven't had a chance to test it with revised ride height
JimSpencer
| posted on 12/9/18 at 07:33 AM |
quote: I bought a used Striker a couple of years back, the suspension set up "as bought" was from the school of, whack up the damping rate
up to the point that the dampers were very stiff, 'cause a stiff car handles, yeah?
Ok so first off you need to fix this bit:-
quote: Though only used on the road
Strikers are at home on a track.. IMHO best £ for £ trackday car you'll come across, I'm probably a bit biased but don't reckon
I'm far off if I am..
Mine (it's a Mk3 BTW) was effectively built 3 times, first time built as a road car with a crossflow/4spd in it, started competing in clubby
hillclimbs locally, and after a few seasons rebuilt it to a 4AGE/5spd and went down the bullet hard route, and it was quicker but not right, too
skittish and didn't inspire confidence. So stripped it back to a bare chassis, had a full cage added, dry sumped, flat floor, race tank etc - in
short more "Race car that happened to be road legal, than road car that you could track" also added a front ARB, protech's valved
for the car, much softer springs and decamped to various tracks for around 3 days in total and dialled it in.
It's ended up at circa 20% stiffer than stock (250/200 IIRC) , quite stiff front ARB though and it's lovely to drive, you can alter its
stance mid corner as you wish, doesn't bite if it does let go etc, very confidence inspiring too.
Currently it only sees the odd track day (running an old single seater instead.) but it's not slow when it does.
Loooking at yours you've got a front ARB which is a good start, if it's still got the old shocks on it worth investing in good ones valved
for the car (Protech's from procomp if I was to recommend) adjust the set up - and get it out there and have a bash, some good venues available
to you to have a play!
