westf27
posted on 28/1/24 at 05:26 PM |
Escort Mk 3 callipers
Overhauling ATE calliper with new seals etc.The slider pins fit inside a rubber tube fitted to the calliper.Question is the original tube has a
plastic sleeve inside it,the new one doesn’t.Slider pin is a tight fit but just concerned whether I have the right tubes,visually they look identical
.Any ideas.
555
westf27
posted on 29/1/24 at 01:17 PM |
Found the answer from the supplier (fall over backwards).
The new slider pin bushes have been designed around not using a nylon insert which is no longer available anyway.
555
