Author: Subject: Dual Master cylinder
ian.stewart
posted on 30/6/24 at 12:30 PM Reply With Quote
Im boxing myself into a corner at the moment with my brake master cylinder on my other toy, an old Triumph Toledo,, the master cylinder sticks out of the bulkhead with a cast ally integral pot, works ok, but its not dual circuit, and I want dual circuit!!!!.
I have changed the engine to a C20XE Vauxhall Twink, and all was great until I changed from Webers to DTH Jenveys,
Now I dont have enough room for my planned master cylinder, its too long and now hits the bodies.
What Im looking for now is a 0.75 or 0.7 short dual circuit M/cyl with the ability to fit remote reservoirs I have a max of length of 140mm !!!! in which to fit the cylinder, I may be able to nick another 10mm but thats it. Any suggestions for something that may work for me
Something different, Very different..............
gremlin1234
posted on 30/6/24 at 02:53 PM Reply With Quote
have you considered 2 master cylinders and a balance bar?
voucht
Contributor
Posts 246
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 30/6/24 at 02:55 PM Reply With Quote
Hi,
140mm is really not a lot, as it seems like even the "compact" Wilwood master-cylinders are 160mm long.
https://www.wilwood.com/MasterCylinders/MasterCylinderLanding
Is there a possibility for you to fit the master-cylinder vertically, or at least at an angle to be able to fit a longer one?
https://vouchtroadster.blogspot.com/
https://caferacer-kawa-gpz-zx550.blogspot.com/
posted on 1/7/24 at 12:13 PM Reply With Quote
Are "reverse master cylinders" an option for you?
I'd never come acress them before, but "Ugg10" shows them in a recent thread...
https://www.locostbuilders.co.uk/viewthread.php?tid=220789
adithorp
posted on 1/7/24 at 05:48 PM Reply With Quote
Do you mean a tandem master cylinder operating a dual circuit brake system?
Dual master, means 2 cylinders linked by a balance bar.
Finding one short enough for your needs is going to be tricky.
http://jpsc.org.uk/forum/
posted on 2/7/24 at 07:28 AM Reply With Quote
No idea what your budget is, but have you considered people like Wilwood?
May even be worth a call to explain yourproblem and see if they have a solution.
[Edited on 2-7-24 by nick205]
