clbarclay
| posted on 27/4/05 at 04:48 PM |
Capri/escort brakes on cortina hubs
I doubt brakes that came off my donor (escort mk2 1300) are standard by a long way. Photo of wide caliper and vented disc in photo archive. I suspect
the discs are capri and the calipers escort (widend) or capri.
Having put the discs on cortina hubs/uprights and tried the calipers on, there is a gap of about 2mm between upright and the caliper mounts.
Is it acceptable (SVA passable) if I make a spacer and use longer bolts to fill the gap?
scutter
| posted on 27/4/05 at 04:58 PM |
I believe their off either a 2.8 Capri or mexico Mk2 Escort, they orignally had a 2-3mm thick washer between the caliper and upright.
No reason you couldn't make your own.
ATB Dan.
RazMan
| posted on 27/4/05 at 06:25 PM |
I found that a standard thickish M12 washer did the trick for me. I am using Wilwood calipers but should be the same.
Raz
DaveFJ
| posted on 28/4/05 at 08:19 AM |
I have 2.8 capri vented discs on cortina uprights with princess calipers, the spacer kit for the calipers came from rally design (IIRC) and included a
set of thick spacer washers to go in between the caliper and the upright.
So basically - yes you'll be fine.
Dave
