Author: Subject: Axle Brackets
caber
posted on 7/4/06 at 07:30 PM Reply With Quote
Axle Brackets
Do you think it is OK to weld the brackets on a Capri axle without stripping it first? I need to get the set up right to measure for new trailing arms and need to get the car on its wheels soon so I can move it!
Caber
MikeR
posted on 7/4/06 at 07:32 PM Reply With Quote
Its not good practice ............ but ............ i did it.
then again i've not actually driven the car yet!
britishtrident
posted on 7/4/06 at 07:36 PM Reply With Quote
Support it properly or it will bend and work out the best order to do the welds in to avoid local over heating.
posted on 7/4/06 at 08:12 PM Reply With Quote
I just drained the oil out of mine then put fresh in after, it's not been a problem. You can't really do a sequence of welds as you want a complete run on each side of the bracket. I just tacked each end with it in place then took it off and finished it in an easier position
Mark Allanson
posted on 7/4/06 at 08:34 PM Reply With Quote
So did I, but I have 4000 miles under may belt now without a single problem
