Author: Subject: brake reducing valve question
dr-fastlane
posted on 5/6/06 at 09:17 AM Reply With Quote
Hello,
After looking by some posts there are some thing not cleair to me. One my car I have ventilated discs at the front, 8” drums at the rear and servo with master cilinder all from an 2,0i Sierra.
Also i’ve got the Brake deceleration valve from the Sierra on my car. And want to replace it for an Brake Reducing valve from an Fiesta or Mondeo. Which one is the best to suite al locost type of car?
This new Brake reducing valve wil not be screwed in to the mastercilinder but on the place where the Sierra valve was fitted (at the back of the car). There for it must fitted horizontal and not vertical like the Fiesta. Somewhere on this forum I read that fitted it vertical it helps bleeding, but effects it the functioning off the valve?
Greets Roy.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
zxrlocost
posted on 5/6/06 at 09:41 AM Reply With Quote
hi Id try your brakes first without one you may not need one
I had a brake problem and it ended up being because I had racing pads
there shite
stuck normal pads in and there fantastic fronts lock up first aswell
JAG
posted on 5/6/06 at 10:08 AM Reply With Quote
I'd agree with zxrlocost.
Try without first. The 8" drumbrakes on the back should give you a good system that doesn't need a reducing valve.
If you do use a valve the physical orientation of the valve body doesn't matter so long as it's not the Sierra G-Valve.
The G-Valve function relies on the valve body orientation. The other types rely on differential orifice/piston area and springs.
Justin
britishtrident
posted on 5/6/06 at 11:30 AM Reply With Quote
Yes first try just joining the pipes at the existing reducer -- just either a puka joining union or a "Tee" with a bleed nipple used to block the unwanted outlet.
[Edited on 5/6/06 by britishtrident]
C10CoryM
posted on 5/6/06 at 03:06 PM Reply With Quote
Sounds to me like your "brake deceleration valve" is known as a metering valve, and your "reducing valve" is a proportioning valve. They are 2 different valves with 2 different jobs. Both are required for good braking on a disc/drum system.
http://auto.howstuffworks.com/master-brake2.htm
Easier than me typing it .
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
