Locost82
posted on 7/6/06 at 11:23 AM |
Halfshaft bearings
How difficult is it to change the Half Shaft bearings on a Mk2 Escort rear axle? Are there any special tools required?
Kissy
| posted on 7/6/06 at 11:47 AM |
Easy'ish
Assume you have the half-shaft out already. You need to get the retaining collar off the shaft. There are 2 ways, 1. Heat it up until it will drop
off - I do not like this as it requires putting a lot of heat into the shaft. 2. Use an angle grinder with a flexy sanding disc fitted to (carefully)
grind it until it is so thin it will just crack under the hoop stress (it is quite easy as it goes blue and the fracture line is easy to see. Remove
the bearing (which should slide off with not too much effort - may need a puller). Push the new bearing on. The new collar (supplied with bearing)
needs to be heated with (ideally) oxy-acetylene to make it big enough to simply drop over the shaft. Allow to cool in air - no water!
BTW - Remember to make sure the bearing retainer plate is on behind the bearing before you drop the collar on (guess how I know!)
Locost82
| posted on 7/6/06 at 11:57 AM |
Sounds like I can do it.
johnemms
| posted on 7/6/06 at 12:46 PM |
I FORGOT TO PUT THE PLATE ON !!!!
HAD TO DESTROY THE NEW BEARING TO GET IT OFF!!!
Forgot all about that with the nice sunny day .... def one of my worst moments in the build.....
stevetzoid
| posted on 7/6/06 at 12:51 PM |
Hi there, I have just had the bearings changed by a man with the gear. A hydraulic press, I watched the operation, First he centre punched and then
drilled the collar and then split it witha chissel, he then pressed off the bearing in the press, Installed the new bearing again on the press and
then installed the new collar again on the press. He supplied the new bearings and fitted them for me for £45.00 well happy he lives out Newark way
any good to you. I think he said it takes about 15 ton to remove the old ones. Regards Steve Evans.
stevetzoid
| posted on 7/6/06 at 12:53 PM |
Oh yes new plates as well.
