mstepien
| posted on 15/6/06 at 01:33 AM |
Funny feeling of Wilwood master cylinder
Hi,
As mentioned in the title, I've an issue with the Wilwood master cylinder, or rather with one of two that I have. I use the .625 for the front
and .750 for the rear. And when I squeeze the rear cylinder, apart from being much more stiff than the front one, the return of the piston is veeeery
slow while the front one moves rather smoothly. Is this normal for the bigger cylinder ? What should be the feeling of a good one ?
FYI the test is performed on dry cylinders so I'm squeezing air only.
Thanks for your help.
Mike
procomp
| posted on 15/6/06 at 06:38 AM |
Hi assuming it is the same pedal box as luego normally use 0.7 cylinders front and rear what calipers are you using up front and is it drum or disk at
rear .
cheers matt
edit- sorry i thought for some reason you had a luego but i see its a mnr.
[Edited on 15/6/06 by procomp]
zetec7
Don't think you can tell with dry cylinders - and the brake fluid lubricates the seals. It might be hard on the seals to pump them too much
when they're dry. Try putting some fluid in the cylinders and see if it's easier...
Winston Todge
| posted on 15/6/06 at 06:42 AM |
Ditto Zetec...
Try not to pump the master cylinders too much when dry as this can damage the seals. You won't get a representative feeling of the pedal without
the system being charged with fluid.
Hope that helps,
Chris.
mstepien
| posted on 15/6/06 at 07:38 AM |
Thx guys,
I decided to leave it as is until I install the whole system and bleed it. Unfortunately it will be some time until then (next spring maybe )
Mike
Hellfire
| posted on 15/6/06 at 08:43 AM |
The seals are designed to work wet, hopefully you've not damaged them.
Instructions? What Instructions?
