Author: Subject: wide rear track standard fronts
ch1ll1
posted on 14/7/06 at 06:08 PM Reply With Quote
what would be the major problem with a wide rear ( standard sierra)
and a by the book front end?
saw one on a car the other day looked weird, but would there be any major handling probs etc?
thinking about doing it to the one im building
cheers paul
[Edited on 14/7/06 by ch1ll1]
scutter
posted on 14/7/06 at 07:23 PM Reply With Quote
I wouldn't ahve thought so, Mine's a standard front end and a Capri (+4" rear.
Handling wise it still sticks to the road like the brown stuff to a blanket.
I think mine doesn't look that too bad.-
[img][/img]
But I maybe bias
ATB Dan.
givemethebighammer
posted on 14/7/06 at 09:06 PM Reply With Quote
It may have a tendency to understeer a bit, but you can correct that to an extent by adjusting ride height / spring rates, tyre pressures etc.
procomp
posted on 17/7/06 at 08:07 AM Reply With Quote
HI udersteer is definatly what you get which is why all the westfield sdv kit owners are having problems . It's not to bad for every day use but if you are going to venture near a track day it will then show up big time.
cheers matt
