DaveFJ
| posted on 24/7/06 at 01:34 PM |
brake re-circulation valve
ok how does this work ?
here
never heard of them before (am i showing my ignorance?)
is there any point?
how does it work ?
cheers
Dave
Syd Bridge
| posted on 25/7/06 at 09:08 AM |
The innards of the valve are based on a pair of non-return (or 'check' ) valves.
When you push the brake pedal, the outlet closes and the wheel cylinders/pistons move. When you take pressure off, the inlet closes and the outlet
opens, allowing the wheel cyl. piston to return and push the fluid back down a return line.
The return can be just a plain metal pipe, which allows the fluid to cool as it returns to the reservoir, or it can be piped through a cooler.
Essential kit (but not necessarily that one ) on endurance type cars, and some rally cars.
Syd.
