Author: Subject: Stud extender spacer combo or new longer studs?
Pdlewis
posted on 9/8/06 at 08:24 PM Reply With Quote
Firstly this topic has probly been covered but not having much luck on the search
Just got some new wheel but when they
have the required spacer the studs are not long enough to get the nut on. I have seen some spacer on ebay which come with nut extenders has anyone used these and do they work?
I would prefert to use these to installing new studs because have an MOT coming up so dont want the car off the road or any excuse for failure
sclough
posted on 9/8/06 at 09:02 PM Reply With Quote
I'd be interested to know the answer to this too. I need to convert 5x98 PCD to something more usable.
Any experiences with hub adapters and spacers would be greatly appreciated.
Humbug
posted on 9/8/06 at 09:12 PM Reply With Quote
If it's just the studs that are too short you are best off getting new, longer studs. I had the same problem and got new studs, I think from Rally Design
Pdlewis
posted on 9/8/06 at 09:16 PM Reply With Quote
sorry for my ignorance but is it a big job to change the studs?
RazMan
posted on 9/8/06 at 09:17 PM Reply With Quote
Stud extenders are not really a good idea - just get some longer studs and swap them over .......... you can do all four wheels in under an hour.
Rally Design supply just about any length you want. Make sure you have about 6 full turns before it nips up.
Raz
Pdlewis
posted on 9/8/06 at 09:21 PM Reply With Quote
yet another silly question the wheels fit fine on the rear without spacers they just catch on the front so will it be ok to just put new studs on the front? or would i need to space the wheels all round?
RazMan
posted on 9/8/06 at 09:25 PM Reply With Quote
Depending on the amount of clearance required it should be ok to put spacers on the front. 5-10mm is not unusual to clear big brakes.
Raz
stevec
posted on 9/8/06 at 09:28 PM Reply With Quote
I used these. Phone up though post and packing is cheap then.
http://www.rallydesign.co.uk/catalog/index.php?cPath=731_735
Anglia66
posted on 10/8/06 at 12:10 AM Reply With Quote
Pdlewis,
Studs are located on a spline so they knock out with a hammer.A squirt of WD40 or similar won't do any harm either.
New studs can be fitted by pulling them through the hole by using a wheel nut,flat side first ,and a suitable spacer.Some thick washers will do.
Fitting spacers on the front only shouldn't be a problem as long as they're not too think.
