Indymike
| posted on 28/10/06 at 02:24 PM |
Diff oil seals
Is there any trick to taking the old oil seals out of the diff? I can't seem to get them out. Tried what Haynes said " lever them out with
screwdriver" but doesn't seem to work.
Any tips?
Build manual? What build manual?
RichardK
| posted on 28/10/06 at 03:13 PM |
I used this Linky Thingy
Regards
Rich
P.S don't forget tp measure the depth normally about 11mm though
| posted on 28/10/06 at 05:24 PM |
you want a big screwdriver with a hex instead of round shaft. stick the blade under the seal and using a spanner on the hex part, rotate the
screwdriver. (nver done it myself but seen it in a book so must be true)
flak monkey
| posted on 29/10/06 at 08:28 AM |
I made a puller up to yank them out with. It was just a large head coach bolt and a bit of tube.
The seals are not a standard size, so you will need to get them ford.
Dont whack a screwdriver between the diff case and the seal or you will damage the seal seating in the diff...
Sera
http://www.motosera.com
andyace
| posted on 29/10/06 at 04:02 PM |
Regards
Rich
Agree, I got mine out with one of these. Nothing else would budge them. Careful not to score the surface with the tool though.
