Author: Subject: Brake bias bar washers.
bigandy
posted on 21/11/06 at 02:22 PM Reply With Quote
Afternoon all.
I need to source some large diamater washers to go between the tube in the brake pedal, and the clevises that go to the two brake master cylinders I have, to stop the clevises rubbing directly on the brake pedal (the clevises are aluminum)
I'm after a external diameter of around 45mm and an internal diameter to suit a 10mm shaft (although this is not important as I can drill it out if it is too small). I guess the thickness needs to be around 1mm or so...
Anyone know where I might be able to buy a handful?
Dammit! Too many decisions....
cryoman1965
posted on 21/11/06 at 02:58 PM Reply With Quote
Not sure if they do them, but M10 penny washers must be near the dimensions required.
HTH
Cheers Nige
RazMan
posted on 21/11/06 at 04:33 PM Reply With Quote
I found some stainless repair washers on eBay which were perfect for the job.
Raz
