The Baron
| posted on 14/12/06 at 06:34 PM |
Track Rod Ends.
I am playing around with a suspension idea, and need some track rod ends the same as the transit one which we use for the top ball joint on our front
uprights but, .................
I need the tread to be small, about 10mm or 12mm 'ish, but the taper on the ball joint bit the same size as the transit!
Does anyone have any ideas?
The Baron
| posted on 14/12/06 at 07:34 PM |
sounds a long shot to me, you might have more luck with a rose joint and a lathe.
