mistergrumpy
| posted on 31/12/06 at 06:54 PM |
Bolt on shafts and subframe
Following on from my bargain thread. How do I get the driveshafts off the subframe? Is it simply a case of removing the torx/hex head bolts and
removing one from the diff. cos they keep rounding and they're tighter than a Yorkshiremans wallet
pathfinder
| posted on 31/12/06 at 06:58 PM |
Yup that’s all, they are tight little feckers, I soaked them in wd40 for a day and still needed to chisel them off!
MikeRJ
| posted on 31/12/06 at 07:21 PM |
Have a search of the archives, long history of removal problems with these little gits.
| posted on 31/12/06 at 07:28 PM |
I can concur that they're a right PITA!!! Soaked them in WD40 for a few days but still no joy. Ended up grinding the heads off to release the
shaft then using a combination of pliers and stud extractors on the resultant studs (didn't have a welder then for the weld-on-a-nut job) I
managed to get them free....
| posted on 31/12/06 at 08:30 PM |
Cut them off and replace with new bolts, has been covered loads of times.
stevec
| posted on 31/12/06 at 10:12 PM |
Give each one a sharp blow on the head, this will shock them and they will come undone easier.
Steve.
givemethebighammer
| posted on 31/12/06 at 10:28 PM |
impact wrench shifted all of mine. Only managed to break one halfords professional T40 bit (which they replaced no questions asked.
smdl
| posted on 31/12/06 at 10:43 PM |
Broke two bits without moving a single one. Finally ground off half of the heads, leaving a semi-circle with one big, flat side, and then used a
hammer and chisel on the top edge of the flat in order to spin them loose in a counter-clockwise manner. As soon as they were broken loose, I could
remove each one with just my fingers.
Hope this helps.
Shaun
[Edited on 31/12/06 by smdl]
mistergrumpy
| posted on 1/1/07 at 12:18 AM |
Ah, so I need to show them a bit of loving eh. Tried a few searches but unless you get the correct words (and english isn't my best language
despite being born here and living here all my life!) you're on a bit of a loser. This search button seems a bit tempramental compared with
some.It'll be computery things no doubt.
