Author: Subject: Another steering rack question
Northy
posted on 30/6/03 at 09:40 PM Reply With Quote
Hi all,
Does anyone know if any other Ford tie rods fit a MKII Escort rack?
I need the tie rods to be about 2cm longer if possible. I've looked at screw on extensions, but this would mean cutting the existing tie rods down, and theading further up the tie rod (if that makes sense).
Burtons do new tie rods, I was thinking Capri or Cortina tie rods???
Graham
kingr
posted on 1/7/03 at 07:53 AM Reply With Quote
On a similar note, what is the lowest number of threads that you can safely have in the track rod end?
Kingr
Northy
posted on 1/7/03 at 09:15 PM Reply With Quote
Anyone?
Does anyone have a cortina or capri rack that whey could measure the tie rods for me on?
If anyone has a rack, would they be willing to peel back the gaitor and take a photo of where the tie rod joins to the rack?
Please, pretty please.....
Graham
Viper
posted on 1/7/03 at 09:22 PM Reply With Quote
Hang on ten mins ad i will do it for you
Graham , took a pic but doubt it will help, mail me i can probably tel you what you need to know.
[Edited on 1/7/2003 by Viper]
Northy
posted on 1/7/03 at 09:34 PM Reply With Quote
Cheers Viper,
Thought you were using a TVR rack?
Just had another thought, what about Sierra tie rods? I've looked in a Sierra Haynes bible and Cortina Haynes bible and they look like they have the same fitting, but no way of telling if the ball is the same, or the length
Graham
Stu16v
posted on 1/7/03 at 09:48 PM Reply With Quote
This maybe a silly question, but what rack are you supposed to use with the Avon?
Have you done something different to warrant modification?
Northy
posted on 1/7/03 at 09:56 PM Reply With Quote
Tiger sell a MkII Escort rack, with longer tie rods for £95, plus £10 p&p, plus VAT!!!!!!!
Tie rods are a little over £7 from Burtons, and I got a MkII rack for £30.
Graham
Viper
posted on 1/7/03 at 10:09 PM Reply With Quote
I am using a TVR rack and i have modded the front, my front end is wider than tiger intended.
kiwirex
posted on 2/7/03 at 08:34 AM Reply With Quote
KingR says:
I'd go for around 1.5 x diameter.
I'd guess much less would be dangerous.
- Greg H
