tegwin
posted on 17/2/07 at 01:33 PM |
Mating TRE with uprights?!?!?!
Im a bit unsure on this toppic, so if someone could shed some light on it...
Im using sierra uprights at the front...Do I mount the track rod ends ontop of underneath the steering linkage on the upright?
And, is this different to how it was mounted on the sierra I.E. Do I need to get the upright modified to take the TRE the other way up than
origionally designed (re tapered)?
Chears.
Dunc
| posted on 17/2/07 at 02:38 PM |
You are getting the track rod end and bottom ball joint mixed up. The track rod fits in from underneath and the bottom balljoint hole needs modifying
to take a Cortina or Maxi balljoint.
stevec
| posted on 17/2/07 at 02:39 PM |
If you mean the steering rack T rod ends then they come up through the bottom.
Without modification,
Steve,
