novacaine
| posted on 25/4/07 at 06:54 AM |
differential
sounds like a strange question but theres method behind my madness......
anybody know if i can get my hands on a 1:1 ratio diff, i was thinking about the centre diff off an evo but i dont know what ratio it is....doesnt
have to be 1:1 exact but as close as possible, needs to be able to cope with a fair ammount of power and torque.....
cheers
Matt
Mr Whippy
| posted on 25/4/07 at 07:21 AM |
never heard of such a beast, wouldn't the pinion cog have to be the same size as the crown wheel weird
what are you up too?
[Edited on 25/4/07 by Mr Whippy]
Duncan_P
| posted on 25/4/07 at 08:54 AM |
I think not asking what he's up to sounds like a good idea
Dont know if these will be of any help
linky
Although they dont go down as low as 1:1 they do go pretty low ratio wise but I dont expect that they are cheap. On the plus side they should be
strong enough to cope with most applications
[Edited on 25/4/07 by Duncan_P]
Confused but excited.
| posted on 25/4/07 at 12:16 PM |
A solid rear axle with a big beefy bevel gear in the middle and one the same size on the end of the prop shaft, will give you what you want. assuming
you want a VERY limited slip diff. ie None.
