graememk
| posted on 2/6/07 at 09:40 PM |
funny noise
went out for a bit of a blat tonight, thought thats a new noise best have a look.
bolts ALL loose on drive shafts both sides arghghghgh, lucky i keep a pocket alan key set with me, whats the best way to keep them in, thred lock ?
whilst i was under there i noticed a bit of grease splashed around, is this because the bolts were loose of will it be something else ?
bob
| posted on 2/6/07 at 09:43 PM |
Could be the bolts or over fill of the CV joints, i did this and sprayed it everywhere till i found some better/proper CV boot ties.
As for the bolts yes thread lock, make sure its all nice and clean before though.
[Edited on 2/6/07 by bob]
Hellfire
| posted on 3/6/07 at 07:51 AM |
We pretty much used Loctite 242 everywhere - it is an anitivibration threadlock which has medium strength - it allows for disassembly. It resists oil
and vibrations. Hasn't failed us once... all bolts remain tight and in place after 3 years unless we broke the seal ourselves. Most all other
places have locknuts.
Hellfire
We pretty much used Loctite 242 (especially the diff area - Ford also use Loctite threadlock on the shafts) everywhere - it is an anitivibration
threadlock which has medium strength - it allows for disassembly. It resists oil and vibrations. Hasn't failed us once... all bolts remain tight
and in place after 3 years unless we broke the seal ourselves. Most all other places have locknuts.
mangogrooveworkshop
| posted on 3/6/07 at 09:38 AM |
Check the bolts holding the bottom rear wishbones to the rear carriers and the top bolts on the mushrooms to the transit upper
balljoints............three cars have had these go slack
