scutter
posted on 31/10/03 at 08:46 AM |
Bolt size
Quick question for you gents,
What size and strength are the larger bolts on a cortina ball joint?
Cheers Dan.
Fast Westie
posted on 31/10/03 at 09:43 AM |
Standard M12s, 30mm long, i.e. 8.8 grade
The car in front is a Westfield
scutter
posted on 31/10/03 at 09:53 AM |
Cheers Westie, thought they were higher strength for some reason.
Dan.
craig1410
posted on 31/10/03 at 01:02 PM |
Hi,
The large ones are 8.8 and the smaller ones are 10.9 in the kit I got from Lolocost. I'm not sure if this is standard or not but may explain why
you though they were higher grade.
Craig.
scutter
posted on 31/10/03 at 07:43 PM |
That could well explain it.
Cheers Gents
Dan.
Mark Allanson
posted on 31/10/03 at 09:57 PM |
I bought 10.9 for both sizes, for the extra 30p for 4 bolts, it gives a little extra peace of mind
type 907
posted on 1/11/03 at 12:54 AM |
If you can keep your head, whilst all others around you are losing theirs, you are probably using 10.9's.
