Northy
posted on 9/11/03 at 09:34 PM |
What front hubs on a Caterham?
Hi all,
Does anyone know what front hubs Caterham use? I've got the chace of some Ali hubs, would they be Cortina or equivalent? They've come off
a Caterham '95 de dion.
Graham
ned
posted on 10/11/03 at 10:33 AM |
Graham,
Not a direct answer, but i do know westfield use an ally cast copy of the cortina hub. they're meant to be a copy of a caterham aren't
they?!!!
Ned.
beware, I've got yellow skin
MikeR
posted on 10/11/03 at 01:00 PM |
I believe for a long time Caterham used Triumph Spitfire - could be a copy of those.
eddymcclements
posted on 10/11/03 at 10:53 PM |
Caterham have their own bespoke front uprights, and probably hubs, too. They are drilled in two different patterns according to which model of car
they're fitted to - the pre-2003 Classic which has an Ital axle and the de-Dion which as the name suggest has a de-Dion axle. Now that live axle
supplies have dried up they're all de-Dion at the rear.
Sorry I can't tell you the PCD, but MikeR is right that many of them will have same stud pattern as Spitfire.
Eddy
ned
posted on 11/11/03 at 09:54 AM |
they have the same stud pattern as a ford, at least they should do as I've got caterham wheels to fit on my cortina hubs!
Ned.
posted on 11/11/03 at 11:07 AM |
You need to know what bearings they use if you are fitting them to Cortina uprights. You should be able to get a bearing to fit if you find the outer
and inner dimensions even if they are different to original spec.
yours, Pete.
