Author: Subject: brake pipes
posted on 9/12/03 at 01:24 PM Reply With Quote
brake pipes
Just about to buy a 25ft reel of brake pipe, will this be enough to complete an MK indy with standard Sierra (drums on rear) brake set-up?
Nick
locoboy
posted on 9/12/03 at 01:44 PM Reply With Quote
I would think so just dont go making too many mistakes!
Locoboy
Staple balls
posted on 9/12/03 at 02:50 PM Reply With Quote
yeah
i had about 2' left over
posted on 10/12/03 at 08:53 AM Reply With Quote
thanks guys!
A bendin' and A flarin' I be this weekend then!
Nick
posted on 10/12/03 at 10:17 AM Reply With Quote
what sort of brake pipe are you using, and is there more than one type? i need to worry about mine soon...! thanks
ps what sort of connectors (size) are used on sierras, my old pipes are long gone...
Staple balls
posted on 10/12/03 at 10:20 AM Reply With Quote
i just got 3/16th (i think!) pipe, and metric unions, seems to go together fine
locoboy
posted on 10/12/03 at 10:33 AM Reply With Quote
a'bendin and a'flarin,
Sounds like a 60's gay rights movement slogan!
Locoboy
posted on 10/12/03 at 10:37 AM Reply With Quote
Steel, copper or kunifer10 brake pipe is available. I use kunifer but it's down to preference or availability I suppose.
yours, Pete.
locoboy
posted on 10/12/03 at 10:42 AM Reply With Quote
pete,
Can you list them in order of price for us? any pro's and con's?
Locoboy
posted on 10/12/03 at 11:03 AM Reply With Quote
I'm not sure what type it is now you ask!!!
It's from my local motor factor, it's Ø3/16 and costs £12 inc VAT for a 25ft coil.
Looking at the colour and bendability it's not steel.
Pete - what is the kunifer 10 pipe you mention?
Nick
posted on 10/12/03 at 03:57 PM Reply With Quote
The kunifer 10 is a copper nickel and iron alloy that doesn't look as pink as copper pipe. It is more resistant to the vibration and work hardening than copper and it doesn't rust like steel. It is type approved for automobile use. The price is comparable to copper and steel is a bit cheaper. A roll of pipe is under £10 at the parts shop I use.
yours, Pete.
posted on 10/12/03 at 05:26 PM Reply With Quote
I reckon that's what I have then, it's definitely not steel and its to grey for Copper.
Thanks Pete!
Nick
RoadkillUK
posted on 10/12/03 at 06:30 PM Reply With Quote
I've found that the Escort rear cylinders and the Cortina calipers that I'm using are both 10x1mm, hope that helps.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
