Ahdammit
| posted on 27/8/08 at 09:30 PM |
Driveshaft question
Hi guys
a car I'm working on has rotoflex couplings and u'j's on the driveshafts.
I'd like to do away with the rotoflex's and fit cv joints instead.
Would the u/j and cv joint combination work ok or is it a bad practice?I cant recall ever seeing this combination before,so I dont know if
they're compatible.
Any advice?
John
[Edited on 27/8/08 by Ahdammit]
mark chandler
| posted on 28/8/08 at 06:37 AM |
They do work, SD1 rovers had CV joint on engine side of the propshaft and UJ at axle end.
Dingz
| posted on 28/8/08 at 12:34 PM |
The rotoflex allow some change in length of the driveshafts as the suspension moves, cheaper than having splined sliding shafts. If you make it solid
there may be no suspension
Ahdammit
| posted on 29/8/08 at 08:25 PM |
Thanks for the replies guys.Dont cv joints also allow changes of length?Surely they must?
