Author: Subject: Brakes
Stuart_B
posted on 3/9/08 at 04:28 PM Reply With Quote
Brakes
hi all, i have got my running gear of a 1.6 sierra, and i got front disc and rear drums, and wonder what type of disc can i put on the front?
as well if i were to change the drums to disc what are the options for the rear?
thanks
stuart
mookaloid
posted on 3/9/08 at 04:36 PM Reply With Quote
You should find that the standard sierra setup will be more than adequate for the 1.6 pinto.
Mark
Guinness
posted on 3/9/08 at 05:20 PM Reply With Quote
I am still using the standard brake set up that came from my Sierra donor, a poverty spec 1.6 pinto, with discs on the front and drums on the back. Although all friction material is new, as are the discs themselves and the calipers are refurbished!
Mike
Stuart_B
posted on 4/9/08 at 12:14 PM Reply With Quote
i saw some willwood brake capliers on some mk on mk open day and was thinking they would look good on my car. and wanted to know can you use and type of serria brakes or is the front hubs differnt?
thanks
stuart
