Author: Subject: sierra driveshafts
gavin174
posted on 14/2/09 at 09:09 PM Reply With Quote
sierra driveshafts
could someone please confirm which goes where..
is th LH the nearside or offside.
cheers
lotusmadandy
posted on 14/2/09 at 09:14 PM Reply With Quote
Yes left hand is the near side.
MikeR
you can work it out by looking at the thread, put a nut on it. Then imagine the wheel turning, it wants to tighten the nut, not undo it.
lotusmadandy
posted on 14/2/09 at 09:19 PM Reply With Quote
Gavin, the sierra shafts are handed anyway.I may be wrong but from memory
the near side shaft is shorter.someone else will confirm or deny in a mo
tomgregory2000
posted on 14/2/09 at 09:44 PM Reply With Quote
left had thread = left hand side
right hand thread = right hand side
gavin174
posted on 14/2/09 at 10:16 PM Reply With Quote
i have just swapped the diff and drive shafts..
i am using a gts dedion.
i have the lh on the nearside, which has movement left to right but the os has no play..
the wheel also seams tight to turn.
are there different length driveshafts as these are a different diameter.
posted on 15/2/09 at 10:08 AM Reply With Quote
i think cossy shafts might be longer by a few mms, but could be wrong.
gavin174
posted on 16/2/09 at 04:17 PM Reply With Quote
i have now swapped the driveshafts over so the lh is on the o/s easier to fit but still no play in shaft...
thinking of getting a 10mm spacer made up for between back plate and hub face.. is there any reason i cant do this..
cheers
