Author: Subject: Anyone familiar with active shocks?
Alan B
posted on 20/2/09 at 08:51 PM Reply With Quote
I believe they work by electronically altering the valving on the fly about 1000 times per second.....wondered if anyone knew about them at all.
SteveWalker
posted on 20/2/09 at 09:36 PM Reply With Quote
Don't know much about them, but I remember seeing a programme about autonomous robotic vehicles and a HUMV in that used active dampers that were filled with a fluid that changed viscosity in a magnetic field and were controlled with electromagnets.
Mark Allanson
posted on 20/2/09 at 09:48 PM Reply With Quote
The Lada system would be the easiest to copy, there is a switch built into the drivers seat, if your ass actually loses contact, the dampers soften up a bit.
Alan B
posted on 20/2/09 at 10:28 PM Reply With Quote
Steve,
The ones you refer to are the magneto rheological fluid dampers....the ones I'm thinking of use regular oil but alter the valve aperture instead.
Mark,
I'm not actually thinking of copying it...but that's a good guess.....no, actually I have an interview at the company that makes them...
Wish me luck..
matt_gsxr
posted on 20/2/09 at 11:31 PM Reply With Quote
You could read this.
http://www.search-autoparts.com/searchautoparts/article/articleDetail.jsp?id=68222
It is american, but the science is international.
Good work to do some pre-interview research, and good luck.
Matt
Alan B
posted on 21/2/09 at 12:11 AM Reply With Quote
Good link, cheers Matt
Steve Hignett
posted on 21/2/09 at 01:57 AM Reply With Quote
There are these fellows. If this is any use?
http://www.youtube.com/watch?v=eSi6J-QK1lw
Fred W B
posted on 21/2/09 at 04:48 AM Reply With Quote
shocks
Hi Alan - hope you are going to call them "dampers" at the interview
Fred W B
Alan B
posted on 22/2/09 at 03:20 PM Reply With Quote
Funny you should say that Fred as they seem to use both words...shocks and dampers on the website. You are right of course that damper is correct.
