dan8400
| posted on 25/4/09 at 10:51 PM |
Sierra drums...handbrake...etc...please help
my SVA retest is this tuesday so i'm really getting worried about my rear brakes. Fitted new cables, shoes, drums and wheel cylinders to the
rear of my tiger. I can only seem to get the handbrake to work on the left hand side. I have tried everything i can think of. Adjusting cables etc
etc. The self adjusters seem to work when the drums are of. (i reset them before refitting). Also the left hand side rear brake (when operated by the
foot brake) locks before any other wheel. It is almost "too good" if there is such a thing.
Can anyone help i am going crazy...
| posted on 26/4/09 at 06:32 AM |
Never yet found an auto adjuster to work . Slacken off the hand brake cable then use a lever on the brake shoe to operate the adjuster one click at a
time, refitting and testing the drum rotates easily each click. Carry on until the drum just starts to bind , repeat for other side. Only then adjust
the handbrake cable .If you have bled the system and all else is well then you should have a decent foot and hand brakes.
dan8400
| posted on 26/4/09 at 08:29 AM |
Thank you for the reply. Do i need to operate the foot brake to set the adjusters before adjusting the handbrake?
philw
| posted on 26/4/09 at 08:45 AM |
No, do as said above adjust them manually until the drum starts to bind(with the handbrake cable slackend off)that way you should have a decent pedal,
then adjust the handbrake cable, and bingo.
Must try harder
dan8400
| posted on 26/4/09 at 08:59 AM |
Ok. Made a start this morning and i think the adjusters are worn. Seem to adjust with the footbrake but i can hear them ping-ing off when i operate
handbrake. Can i somehow regroove them? Just thinking of ways i can make it work today. Retest on tuesday and hoping to use local garage rolling road
tomorrow.
jacko
| posted on 26/4/09 at 09:10 AM |
photo the brakes and let us see them
dan8400
| posted on 26/4/09 at 09:19 AM |
Ok, just done a quick test in the vice. The adjuster taken from the side that worked cannot be moved in any position when i lean on it with a
screwdriver. The adjuster from the side that is faulty can be pushed back from any position. The little grooves are worn down too much i think.
So i need a pair of auto adjusters for sierra drums. Anyone got any? Could really do with them today. OR is there any chance i can somehow re-use
these. Somehow re-groove them?
[Edited on 26/4/09 by dan8400]
SteveWalker
| posted on 26/4/09 at 10:30 AM |
I can't remember the geometry of the setup, so I don't know if regrooving them will work or if the radius of the quadrants would be too
small. If re-grooving would work, then maybe a Dremel? It may be that the adjuster would wear very quickly after this, but you can replace them next
week.
dan8400
| posted on 29/4/09 at 06:06 AM |
Ok, what i did was set the adjuster to where i wanted it then welded it to stop any movement. I know it's heath robinson but managed to pass
sva. Getting new parts this week but as a temporary solution it was ok
