Author: Subject: Odd Sierra Front Brake Prob.
BigDawgV8
posted on 26/4/09 at 08:46 PM Reply With Quote
Hi All,
I must of put about 800 miles on my car since finishing it last year and the brakes should be bedded in by now and they are..........on 3 wheels...............
On the front n/s, the outside pad only touches the disc on the outer 1 inch of the disc. The rest of the friction surface is untouched (and rusty!)
I have removed the pads, cleaned and refitted but they don't seem to want to bed in on this one wheel. ODD!
As far as I can see nothing is bent or out of line.
Any ideas anyone?
Martin
handyandy
posted on 26/4/09 at 08:55 PM Reply With Quote
sounds like the caliper piston on that pad is either siezed or been put in at (forced in) at an angle & so not smoothly pushing pad against the disc , but then again i maybe wrong, not easy without seeing it. but hope that helps.
andy
BigDawgV8
posted on 26/4/09 at 09:06 PM Reply With Quote
Thanks.
Calipers were exchange recon units.
The ''odd' pad is on the outside. With sliding calipers is it possible that the piston can affect the outer pad??
I would have thought the pins would keep it square?
mad4x4
posted on 27/4/09 at 06:28 AM Reply With Quote
Have you checked that the PINs are Straight and well lubed could be sticking on them.
Scot's do it better in Kilts.
posted on 27/4/09 at 06:35 AM Reply With Quote
Easy to test the caliper by removing the pad and giving the pedal a very gentle press to about 1/3 travel -- I think you will find the caliper is NBG return it.
