Author: Subject: track rod ends again
aka Keith
posted on 13/5/09 at 07:44 PM Reply With Quote
Well my new Quinton Hazell track rod ends arrived today. MK indy Ford sierra set up.
Quick question, do I need to grease them/or do anything before fitting them.
Also, anybody got any idea what the torque setting is for the nuts?
Craig
robinj66
posted on 14/5/09 at 05:15 AM Reply With Quote
The locknuts are 42-50 lbf ft [57-68 Nm]
The nuts on the ball joints (to the hub carrier) are 15-24 lbf ft [20-32Nm] and then tighten to next available pin hole.
All the above according to Haynes.
I always use a smear of grease when fitting the TRE to the rack end. Don't use grease etc on the balljoint nut if using a nylock.
posted on 14/5/09 at 09:43 AM Reply With Quote
A bit of copper slip on the track rod threads will help prevent the TRE seizing up, you'll be glad you did it when you come to adjust the tracking next time.
