Author: Subject: Another brake binding problem
Jasper
posted on 25/5/09 at 03:21 PM Reply With Quote
Different one this time, both front brakes bind at odd times, can be from cold and hot, and if I hit the brake pedal hard a couple of times (when stationary) they release.
So I presume it's something to do with the balance bar? I'm using Sierra callipers (new) with Ferodo racing pads.
adithorp
posted on 25/5/09 at 07:34 PM Reply With Quote
Sounds like your master cylinder push rods aren't able to completely return. Adjust them in the clevis on the pedal to give slight play at rest.
adrian
http://jpsc.org.uk/forum/
posted on 26/5/09 at 07:57 AM Reply With Quote
In addition to the above you might need a return spring on the brake pedal
Jasper
posted on 26/5/09 at 11:23 AM Reply With Quote
Thanks chaps - I'll give that a go....
