Irony
| posted on 18/8/09 at 02:11 PM |
Brake line Brackets - where from and the best?
Hi all,
I am looking at pinning my brake lines back to the chassis and I am wondering what other people used and where they got them from. Cable ties seemed
the simplest solution but they are not very nice looking and the IVA man probably won't like them.
any thoughts?
blakep82
| posted on 18/8/09 at 02:13 PM |
rubber lined P clips are good, or you get sort of push on clip ones too.
if you do a search on here theres plenty about them
________________________
Irony
| posted on 18/8/09 at 02:25 PM |
aha I was searching for brackets rather than clips, cheers
| posted on 18/8/09 at 03:52 PM |
Best to use OEM style push in clips as gives a a profesional finish and they keep the pipe clear of the chassis, you can also get double ones , and
double ones and ones that take both brake and fuel lines.
Pclips tend look a bit B&Q
Canada EH!
| posted on 18/8/09 at 04:28 PM |
One concern with the push in clips is moisture getting inside the chassis. IHMO the P clips held on by rivnuts, also easy removal.
Nash
| posted on 18/8/09 at 05:08 PM |
Rubber lined P clips without a doubt is the way to go
....... Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Dangle_kt
| posted on 18/8/09 at 05:46 PM |
if you choose P clips, get stainless with rubber lining, or they will look tatty very quickly.
clairetoo
| posted on 18/8/09 at 05:48 PM |
I used the push in clips when I built mine , with a smidge of sykaflex to seal/glue them in - that was ten years ago , and they are still
there........
Its cuz I is blond , innit
Claire xx
Will weld for food......
