P ?
| posted on 13/9/09 at 09:42 AM |
needed p clips today
hi all just planned a good afternoon in the garage fixing my brakelines but im missing the final ingredients!!
P clips for some reason i forgot about buying them
question is where would i be able to pick some up what size and what fixing size rivets needed..... its too early to think, did think of halfords but
no look..... anyone got a good idea all help welcome and thanks inadvance
cheers Mark
ruskino80
| posted on 13/9/09 at 09:46 AM |
where in the country are you-i have a box full
AdrianH
| posted on 13/9/09 at 09:47 AM |
If after nylon P clips try Maplins if you have one near you.
Adrian
Why do I have to make the tools to finish the job? More time then money.
P ?
| posted on 13/9/09 at 09:51 AM |
doncaster way :S
cheers adrianh
maplins always forget to think maplins cheers what size do i require and size rivets? would i be able to get rivets from maplins?
miikae
| posted on 13/9/09 at 09:57 AM |
Speak to your local electrician of failing that pop in to any electrical wholesaler as they will have all plastic and plastic coated metal ones as
used on Pyro installations, fire alarms etc
A motor factors shop may have them if you are lucky.
Mike
[Edited on 13-9-2009 by miikae]
If it can be done it i will be done .
P ?
| posted on 13/9/09 at 10:00 AM |
cheers will do... breakfast is served then straight too the shops cheers again all
big_wasa
| posted on 13/9/09 at 10:03 AM |
Solid Brake lines are 3/16" from memory.
edit = 4.8mm
[Edited on 13/9/09 by big_wasa]
P ?
| posted on 13/9/09 at 10:18 AM |
edit = 4.8mm
noted
ashg
| posted on 13/9/09 at 11:23 AM |
maplins.
they are pretty cheep too. i used 3.2mm rivets.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
