goodguydrew
| posted on 14/9/09 at 09:55 PM |
Front lower A arm touches bracket
What angle is acceptable for the lower front wishbone to touch the rear bracket at its maximun angle below the horizontal? I hope mine are not binding
too soon? I don't have an agle to quote. Any thoughts?
Andrew.
daviep
| posted on 15/9/09 at 03:47 AM |
If I understand your question you are asking how far the bottom wishbone should be able to droop before before it hits the chassis/bracket?
Doesn't really matter as long as what ever shocker you have fitted prevents it fouling. If with the shock fitted the arm contacts anywhere then
you have a problem and will need shorter shocks or to move the pick up points.
Davie
mad-butcher
| posted on 15/9/09 at 08:00 AM |
I think you'd be running about 18" ground clearance if your bottom wishbones were hitting the bottom rail, general school of thought says
start off with them parallel about 4 1/2 " ground clearance
tony
[Edited on 15/9/09 by mad-butcher]
