Author: Subject: how have you held your steering link in the rose joints?
andrew-theasby
posted on 27/9/09 at 11:37 PM Reply With Quote
Looking at the mcgill rose joints to hold my steering link in place, they dont do a 15mm one for my rally design link rod its 14 or 16mm. How have others held them in place and does the shaft spin in the ball, or is the shaft attached to the ball somehow to spin the ball in the housing. Was thinking of going to 18mm and making a little bush
[Edited on 27/9/09 by andrew-theasby]
blakep82
posted on 27/9/09 at 11:41 PM Reply With Quote
it should be a decent close fit, but just pass the shaft throuh the ball, no need to attach it, kjust as long as it doesn't rattle side to side in there its fine
________________________
andrew-theasby
posted on 27/9/09 at 11:44 PM Reply With Quote
i think 16mm will be too loose then wont it? am i best turning it down to 14mm?
blakep82
posted on 27/9/09 at 11:52 PM Reply With Quote
i think bigger, then make a bush to fit was a good idea. what do you call it? and interfence fit? so the bush is real tight in the rose joint and won't move anywhere, and then put the shaft through the bush. might be a bit fiddly, but i think is a better idea than turning the whole shaft down.
legends cars use a 3/4" steering shaft, and 3/4" rose joints at the top (2 of them)
actually, whats the metric equivalent of 3/4"? its not far off 15mm is it?
edit: no forget that. 15mm is 0.59" or something, so what about starting with a 1/2" rose joint, and using a tiny grinding thingy on a dremmel to open it out slightly?
[Edited on 27/9/09 by blakep82]
andrew-theasby
posted on 28/9/09 at 12:38 AM Reply With Quote
Arent they hardened? Can soon make a sleeve though, is this the norm? Thanks
blakep82
posted on 28/9/09 at 12:50 AM Reply With Quote
not sure. i got 14mm ones from mcgill a few years back for my steering column, and they were too tight a fit, so i managed to grind them out a little to fit. but then i went for a complete change of plan, and spent £200 on a complete steering column from SHP
dinosaurjuice
posted on 28/9/09 at 08:26 AM Reply With Quote
McGill sell a rose joint for the purpose of steering column support. its 3/4" + a few thou clearence.
15mm seems a bit small for a column...
andrew-theasby
posted on 28/9/09 at 08:34 AM Reply With Quote
its what rally design sell, i dont mean the actual collumn, ive got the proper sierra bush for that, its the short splined bit that needs supporting
blakep82
posted on 28/9/09 at 10:11 AM Reply With Quote
how many UJ's have you got? if you've only got 2 it shouldn't need supporting
any photos?
andrew-theasby
posted on 28/9/09 at 10:32 AM Reply With Quote
Theres 3 u/j's as i couldnt get the required angle for the IVA with 2, so it does need supporting.
