Author: Subject: electric hand brake
bj928
posted on 11/12/09 at 01:16 AM Reply With Quote
electric hand brake
As i believe a few car makers are building cars with a press button hand brake(BMW 7 series), does that mean its ok for IVA, or do i have to still have a cable.
richardlee237
posted on 11/12/09 at 05:41 AM Reply With Quote
See below extract from IVA manual.
The way I read it is that it can be operated electrically but must stay on by mechanical locking even if there is no electrical power.
9.
The ‘parking’ braking system must be capable of being operated using a control which is independent of the service brake, and once applied capable of being maintained in the ‘on’ position solely by mechanical means.
Brake Systems 09A
Revision: 1 Date: 27/03/2009 2 of 4
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
prawnabie
posted on 11/12/09 at 06:50 AM Reply With Quote
Most of the electric handbrakes I have worked on are just 2 cables connected to an electric motor in a box with a "rachet" mechanism to retain the braking in case of failure and a emergency release.
The electronics on them are more complex as the vheicle montiors the wheel speeds for a while after the vehicle is parked in case of failure. The computer controlling the system would also need to recognise the biting point of the car release the handbrake.
turbodisplay
posted on 11/12/09 at 11:01 AM Reply With Quote
I would have some sort of feeback indicator to show if the tension is not enough.
Maybee a spring with a microswitch "sensor".
Also you have to think of the brake test function, that is normally dealt with the handbrake switch.
Darren
[Edited on 11/12/09 by turbodisplay]
posted on 11/12/09 at 02:46 PM Reply With Quote
The simplest electric handbrake systems used a worm and pinnion or screw and nut mechanism as in a screw jack --- the fancy name for these is overhauling mechanisms. In simple terms think of a screw jack, turning the screw will raise the load but the static friction is to great for load to turn the screw. So if you jack the load up it stays up.
morcus
posted on 11/12/09 at 04:35 PM Reply With Quote
I wouldn't think the hand brake would need any kind of setting to the biting point as they don't turn off automatically, you'd have to time it your self like a normal one. I know someone who rented a Vauxhall with an electronic handbrake and he said it was really annoying because it turned itself on so he was driving with it on.
It must be IVA legal in some form, a few people in the trade i've spoken to reckon it'll be standard for production cars befor long.
posted on 11/12/09 at 06:04 PM Reply With Quote
The use in production cars is all to do with engines turning themselves off at the traffic lights --- ugh
Howlor
posted on 11/12/09 at 06:13 PM Reply With Quote
Mine passed no problem with SVA. Worm driven with adjustable limit switches to control the worm motion. My particular drive could pull IIRC 70Kg but required 2500kg to unwind it!
prawnabie
All the ones I have worked on have turned off just as you hit the biting point.
bj928
posted on 11/12/09 at 06:35 PM Reply With Quote
thing i'm going to have to look at options, i was looking at using a line lock, but that needs power to stay on and the electric line locks are only designed for max of 60 second use, thanks for the feed back
bj928
posted on 11/12/09 at 06:48 PM Reply With Quote
looks like the ford c max uses a self contained electric cable pulling electric hand brake, not cheap at £150 used, but guess it would work.
http://cgi.ebay.co.uk/06-08-C-MAX-CMAX-ELECTRIC-HANDBRAKE-MOTOR-CABLES_W0QQitemZ120504092289QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash= item1c0e9a8681
Howlor
posted on 11/12/09 at 06:51 PM Reply With Quote
This kinda thing is like I used.
Linear Actuator
posted on 11/12/09 at 09:58 PM Reply With Quote
A line lock of any kind would defo not be allowed ----
bj928
posted on 12/12/09 at 02:10 PM Reply With Quote
this looks interesting.
Linear Actuator
