Author: Subject: Quaife into Lobro 7"
The Knobs
posted on 17/12/09 at 08:22 AM Reply With Quote
If I fit a Quaife lsd into my diff, can i reuse the existing lobro shafts or do i need new ones specifically for the quaife unit ?
Diff is a standard sierra 7" lobro type.
Wadders
posted on 17/12/09 at 08:53 AM Reply With Quote
AFAIK quaife only do an lsd to suit push in shafts.
To get round this i had custom shafts made by GB engineering with push in splines at the diff end and lobro splines at the hub end.
There would be other ways to get round it of course.
Al
turbodisplay
posted on 17/12/09 at 09:24 AM Reply With Quote
Wadders,how much was that to be made?
I`m looking for something like that for my front diff to use cv joints.
When you say lobro side you mean the 6 hole flane?
Darren
minitici
posted on 17/12/09 at 09:31 AM Reply With Quote
Quaife also manufacture their 7" ATB diff complete with the Lobro bolt-on type output flanges.
Linky
£775+vat
antonio
posted on 17/12/09 at 09:33 AM Reply With Quote
trann-x offer a LSD wich can be made to suit your application.when i bought mine, they told me they can supply push or bolt in type.if it helps...
mcerd1
posted on 17/12/09 at 10:32 AM Reply With Quote
Linky
£775+vat
yeah, but its alot more expencive
I thought that all you had to do was a cut a circlip / snap ring groove on the ends of the stubs (or something like that)
but you definatly need the standard open centre ones (equal length) as the ford LSD type stubs don't work (ones longer than the other)
classic conversions used to do this but there website's diapeared again (I've got a couple of phone numbers you could try - stuart is realy easy to deal with)
The Knobs
posted on 17/12/09 at 03:55 PM Reply With Quote
So would these be what is required plus the normal quaife 7"lsd ?
http://cgi.ebay.co.uk/Stub-shafts-to-suit-Ford-Sierra-7-Differentials-Pair_W0QQitemZ180442884517QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?h ash=item2a033be9a5
Chippy
posted on 17/12/09 at 04:26 PM Reply With Quote
I recently purchased a diff with a Quaife LSD in it, all brand new. Contacted Quaife to see if I could use my Lobro's, "No you need to buy one of our Lobro LSD's", so contacted again and said what is diffent with your Lobro unit, why won't my Lobro's fit, "You will have to buy one of our Lobro LSD's". So all in all not a very helpful company, and I would say there Tech. dept. has "F" all knowledge of there products, and even less in customer care.
Cheers Ray
CNHSS1
posted on 22/12/09 at 10:43 AM Reply With Quote
i have a quaife and when i changed from push-in to lobro i just used a pair of lobro input shafts from a NON LSD sierra diff, much cheaper than quaifes versions
Liam
posted on 22/12/09 at 01:11 PM Reply With Quote
The problem with inserting the standard flanges is you can't get into the quaife diff to fit the circlips. Not a problem with the push-in shafts as they are held in by the sprung tripode joints. The lobros aren't sprung, so without the circlips there's nothing stoping the shafts working their way out of the diff, at least past the oil seals, and maybe to the point of doing some major damage.
Liam
[Edited on 22/12/09 by Liam]
mcerd1
posted on 22/12/09 at 08:53 PM Reply With Quote
thats why classic conversions were modifing them to use some kind of snap ring or something (never got the details as I stuck with a ford LSD for now)
[Edited on 22/12/09 by mcerd1]
