Author: Subject: checking brake calipers
Miks15
posted on 18/12/09 at 03:39 PM Reply With Quote
Ive changed the seals on my front brake calipers, and i also had to drill out and re tap one calipers bleed nipple.
I want to just check theyll still work properly before i out them on the car. Is gthere anyway to do this?
mookaloid
posted on 18/12/09 at 04:32 PM Reply With Quote
how did you make sure that you drilled and tapped perfectly centrally? if it is even slightly off then the nipple might not seal properly and cause a leak
Miks15
posted on 18/12/09 at 04:52 PM Reply With Quote
hence why i want to check it
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 18/12/09 at 05:02 PM Reply With Quote
wouldn't bleeding them soon find any leaks, you could connect the hoses and just g-clamp the callipers or just fit them on and try bleeding, if theres a leak they wont bleed properly
dhutch
posted on 18/12/09 at 05:16 PM Reply With Quote
Fit them and test them on the car....!
Miks15
posted on 18/12/09 at 05:30 PM Reply With Quote
i dont have all my hoses and stuff yet, and if there ot right then il buy some E46 brakes (vented discs and my hubs are E46, current brakes are E36 and have to be spaced to fit)
So dont want to get my hoses and everything to find they dont work and i need new calipers discs and hoses, might just get the bigger calipers and discs anyway, not that expensive
Ben_Copeland
posted on 18/12/09 at 06:11 PM Reply With Quote
Without hoses and hydraulic pressure you cant really test them, cheaply.
I'm guessing someone has a machine somewhere, but would be cheaper to get some old hoses and rig them up somehow.
Miks15
posted on 18/12/09 at 07:36 PM Reply With Quote
i snipped my old hoses when stripping the Beemer
I think im just going to go with a newer set of calipers to go with my hubs, that way i get vented discs aswell!
Steve G
posted on 18/12/09 at 08:15 PM Reply With Quote
Do you really need vented disks? They are a fair bit heavier and you arent likely to need the extra cooling capacity of the vented disks on a lightweight kit.
I'd be tempted to get a hose from a breakers and go straight off the master cylinder to the caliper in order to pressure test it.
posted on 19/12/09 at 10:49 AM Reply With Quote
one way to connect air line, then a bit of water with washing up liquid applied to the nipple area will show up leaks as bubbles.
you'd need to put a block of wodd between the pistons to stop them popping out.
ofcourse an airline won't reach same sort of pressure hydraulics do but if it leaks, then you know you need to reassesss the sssituation.
