Author: Subject: what are brake discs made of?
blakep82
posted on 24/12/09 at 01:45 PM Reply With Quote
are they just plain mild steel?
or a special grade, or alloy?
thinking of handbrakes again, forgot about the prop disc types. i've got sierra rear calipers on the back, but wonder if a prop mounted disc might make the cabling easier
________________________
posted on 24/12/09 at 01:46 PM Reply With Quote
Usually SG cast iron
will121
posted on 24/12/09 at 01:48 PM Reply With Quote
does a prop disc work with a open differential?
blakep82
posted on 24/12/09 at 02:07 PM Reply With Quote
thanks BT. makes my idea of getting one machined to fit the prop a little more difficult it think.
will, good question... it should do, since if the car is trying to roll backwards or forwards, it should be trying to turn the prop anyway, but it wouldn't work if the car was trying to spin round on the axles axis. how likely is that ever going to happen?
greggors84
posted on 24/12/09 at 02:10 PM Reply With Quote
It should do as its only like leaving your car parked in gear.
Unless one wheel is in the air/no traction I think.
[Edited on 24/12/2009 by greggors84]
Chris
The Magnificent 7!
motorcycle_mayhem
posted on 24/12/09 at 02:22 PM Reply With Quote
BMW often fitted stainless discs to their motorcycles, I know this, I've had one (or two). NOT the best friction disc material in the world, doesn't have the bite of cast iron, but it doesn't rust either..... which is why I assume they fit them.
Aftermarket cast iron discs are a-plenty.
posted on 24/12/09 at 02:53 PM Reply With Quote
Pads have to be special grade for stainless steel.
Transmission brakes are something to avoid at all if possible.
will121
but if its not will it be ok if not same brake levels for Mot etc??
hillbillyracer
posted on 24/12/09 at 07:36 PM Reply With Quote
Landrover have used a transmission mounted drum brake for the handbrake for years, mabye as long as they've been in production!
The biggest problem is both wheels must have grip for it to hold, if either can spin then it could move. A LSD would help a lot dependant on it's operation.
boggle
posted on 28/12/09 at 06:34 PM Reply With Quote
you can use stainless for a transmision brake as it should only be used to keep the car statinary as opposed to stoping it (unless in an emergency), rally design used to do a mechanical calliper that was ideal for this...
u2u me for details
