Worzey
| posted on 28/2/10 at 11:24 AM |
New shocks and bushes
I've got two leaking shocks on my Velocity - one on the front and one on the back.
They are the standard supply GAZ shocks. I need to decide what I do now.
I believe its best to change all four at the same time but can I move a good front to replace the leaking back without too many negatives?
If I go with my preferred option of replacing them all what are my options? Do I stick with GAZ or put on a different brand, if so what are your
suggestions and why?
It's going to be used mainly as a track/fast road car so I want the option that gives me the best performance/weight reduction/feel (subjective
I know).
Finally, my rear bushes are shot (usual Luego issue) and need replacing. I think I need the poly bushes and crush tubes. Am I best going back to
Luego, have they sorted the bush size issue at their end?
Can anyone suggest alternatives I can use that will fit straight off? Again, performance and reliabilty are the key requirements.
[Edited on 28-2-2010 by Worzey]
Caterham R400
philw
| posted on 28/2/10 at 11:31 AM |
Won't the front and rear shocks be different lengths?
Must try harder
Worzey
| posted on 28/2/10 at 11:34 AM |
I'm not sure - I've never checked the sizes - I just assumed they were the same.
Anyone know what sizes they are front/rear?
Caterham R400
alexg1965
| posted on 28/2/10 at 12:10 PM |
The shocks on my Velocity were the same length (13" . The coils are different though but you're not replacing them.
ashg
| posted on 28/2/10 at 02:26 PM |
gaz will rebuild them for you why do you need new ones? call and speak to mark. they usually turn them round in a day or two and they come back like
new
my gaz shocks were all dyno'd and paird up.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
austin man
| posted on 28/2/10 at 02:33 PM |
send them away and have new seals fitted, it will save you a fortune.
I have pro comp ones on mine and can vouch for an exceptional level of service from them.
