bassett
| posted on 4/3/10 at 01:19 PM |
Brake fluid hose
Hi, firstly is this the correct place for braking needs? i think one of my hoses that joins the resevoir to the master cylinder is leaking as if i
touch the hose it leaves my hand slightly greasy like brake fluid although nothing drips. The hose has a proper clip on it to seal aroung the
reseviour barb outlet and the same on the end that joins the flared copper pipe that meets the cylinder. I am sure the hose im using is the correct
stuff (rubber hose with fabric braiding) from merlin motorsport but i would have expected it to last longer than 8months. What is permanent solution
for this if i need to replace it after some more checks?
Adam
[Edited on 4/3/10 by bassett]
cd.thomson
| posted on 4/3/10 at 01:22 PM |
there was a thread about this recently. Are you using fully synthetic brake fluid (DOT 4)? As this is what the fabric covered hose is designed for.
Craig
r1_pete
| posted on 4/3/10 at 01:58 PM |
I just bought some of THIS from CBS, comes with an IVA cert stating it
is for brake fluid...
cd.thomson
| posted on 4/3/10 at 02:00 PM |
again, only for fully synthetic brake fluids
Craig
bassett
| posted on 4/3/10 at 02:06 PM |
Currently using some cheapo dot4 and thinking about going for some fresh super dot4/5.1
jimgiblett
| posted on 4/3/10 at 05:01 PM |
Shouldn't be anything wrong when basic DoT4 unless you are generating hooge amounts of heat and then you'll need something like AP600 (DoT
5.1). I would be very impressed if you can generate these sorts of temps in a lightweight car.
- Jim
[Edited on 4/3/10 by jimgiblett]
r1_pete
| posted on 4/3/10 at 05:17 PM |
CBS' description says ALL types of brake fluid......
bassett
| posted on 4/3/10 at 10:51 PM |
il check it over this weekend as maybe its just from the initial bleed when it all got a bit messy or something worse like a sharp edge on one of the
flared pipes from the cylinder. The brakes have had an easy life so far and even when it does get on the track i doubt we would be able to get it hot
as we'd be too scared of pranging it
