robocog
| posted on 15/3/10 at 06:30 PM |
tyres, whats hot - whats not?
Ok so having moved to 13"'s from 14"s I'm looking for rubber I'll be happy with for the next couple of years
Car has not yet been on a track day and I'm not planning on doing any yet
I just want a tyre that will work well with a light ish build, don't mind replacing them every 3 years even
Have tried Semperit Speed comforts in 195/60 r14's and they seemed nice and light when I was comparing tyres in the shop ...however the side
walls were very thin and soft qiving a squirmy ride, and I seemed to eat the middles of the treads at an alarming rate suggesting they were
overinflated (despite me only having 16 psi in the rears and just over a year of use out of them!) any less pressure and the tyres really were
stupidly soggy
I have a set of part worn - but looked like they had been recently fitted and hardly worn in - Champiro BXT's on the 13's at the mo
(185/60 r13)
The dates on them are just under 3 years old and they look OK,eg not perished
However they are all horrendously lopsided!
The guy balancing my wheels was pretty horrified - rims all seem to run true but the tyres were all over the place...so it looks like I'm up for
a new set of 4 round rubbery things
I have been trying to get quotes on premium brands in 185/60 r13 and so far have had
Yokohama A539's at £60 a pop (local fitters
R888's quoted from Camskil at £144 a corner (which will not be happening at that price! was under the impression they were only £50 odd a corner
so had a shock when they quoted £576 all in)
What else should I be considering?
Are A539's going to be OK ?
Regards
Rob
[Edited on 15/3/10 by robocog]
dlatch
| posted on 15/3/10 at 06:36 PM |
won't go far wrong with the A539's
also i have always liked the toyo tyres on tintops but not tried on a kitcar
richardh
toyo proxey r1's ? used them in the wet and dry and were good
Time for a change!
norfolkluego
| posted on 15/3/10 at 06:44 PM |
Toyo T1R is a cracking 'budget' tyre, picked some (new) 15 inch ones up last year from eBay for £116 delivered
gottabedone
| posted on 15/3/10 at 06:47 PM |
Had Proxes and 539 and they were both ace - Pirelli 6000's are crap and wouldn't ever use them again.
philw
| posted on 15/3/10 at 06:49 PM |
I used them on my TVR when i had it and rated them, i don't particularly like them on the kit it doesn't seem to be heavy enough to work
them properly.
Must try harder
| posted on 15/3/10 at 06:51 PM |
T1-R? They are not available for 13" rims.
The Toyo R888 is shown
here for £48
(probably +vat)
StrikerChris
| posted on 15/3/10 at 06:56 PM |
539's for me.best all rounder i've fitted to the imp,and proper tin top and now on the striker for road use.also had falkens afew years
back,a directional tread,was impressed with them for the price,but couldn't say on a light car,and my 8v astra gte ate the fronts in
3000miles.that said it was probably more to do with my age than the tyres at the time!
GeoffT
| posted on 15/3/10 at 06:57 PM |
I think the trick is finding tyres that are soft enough to work on a car half the weight of your average tintop.
I found 539's to be ok in the dry, but tended to lock up far too quickly under braking in the wet on a seven weight car.
Lots of variables involved when comparing tyres though, a bit of a minefield really......
Edited to add that 888's definitely do work - if you can get them for the price shown in the link above I would grab 'em quick....
[Edited on 15/3/10 by GeoffT]
eddie99
| posted on 15/3/10 at 06:59 PM |
I've recently had Bridgestone ER300 on the tintop, Great tyre. Unsure what they would be like on the kitcar but excellent for a light tintop.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
se7en
| posted on 15/3/10 at 07:10 PM |
I have used Marangoni tyres on my tin top with very good results. I found that the walls are quite stiff thus
less roll and their grip in the wet is exceptional.
From memory they were not expensive and they did last the mileage.
Hope this helps
Tom
alistairolsen
| posted on 15/3/10 at 07:16 PM |
on a tintop I rate kumho ku31 ecsta sports or uniroyal rainsports over the toyos or goodyear eagles. For the kit I will be going for r888s due to the
weight issue.
You mention changing them every three years? Id be changing them at least that often regardless of wear tbh.
My Build Thread
franky
| posted on 15/3/10 at 07:17 PM |
toyo t1-r's.... designed to work on lightweight cars.
ReMan
| posted on 15/3/10 at 10:10 PM |
Proxies get my vote too
| posted on 15/3/10 at 10:52 PM |
