Author: Subject: Sierra Rear Hub Bearings
IainL
posted on 24/3/10 at 06:14 PM Reply With Quote
Where's the best place to get Sierra Rear Hub Bearings from, and do I need to know if the original hubs came from a car fitted with ABS?
How can you tell if the hubs have come from a car fitted with ABS?
mad-butcher
posted on 24/3/10 at 07:05 PM Reply With Quote
If it's ABS it will have a toothed ring and I don't think there is any difference in bearings
tony
mcerd1
posted on 24/3/10 at 07:17 PM Reply With Quote
I think the ones with rear discs are different from the ones with drums (I could be wrong though)
any decent motorfactor will have them - but they'll want to know what model of sierra its for
mad-butcher
posted on 24/3/10 at 07:37 PM Reply With Quote
The rear bearing carriers are different, disk brake ones have 2 ears to mount the caliper, toothed ring is on the shaft
tony
Tris
posted on 24/3/10 at 09:10 PM Reply With Quote
This Picture shows rear sierra hubs, the one on top with its toothed ABS ring still in place, the one on the bottom with it removed (as i don't need it and it interferes with my new, none sierra bearing carrier).
I think the bearings are the same however. There's loads available on ebay.
[Edited on 24/3/10 by Tris]
Xtreme Kermit
posted on 24/3/10 at 09:36 PM Reply With Quote
got mine from local motor factors.
Mine are for drum braked hubs. I think the bearing must be different, and the length of the splines on the shafts are way different between disk and drum varieties.
Sorry I haven't got the part numbers, but I just asked for 2.0l sierra 1985, no abs.
Xtreme Kermit
posted on 24/3/10 at 09:40 PM Reply With Quote
ahah! found a picture.
Drum brake version on the left. Ignore the one on the right as they are like hens teeth - drum brake lobro shaft version...
