speedyxjs
| posted on 1/4/10 at 04:36 PM |
Glueing magnets to prop
Iv just picked up my shortened prop ready for my first drive at the we hopefully
One thing i wanted to check though, if i glue four magnets for the speedo to the prop, will that imbalance it enough to be even slightly worried about
failure?
twybrow
| posted on 1/4/10 at 04:40 PM |
I sent my magnets, and epoxy putty to D&F when they rebuilt my prop. They balanced it after bonding the magnets on, and I was surprised how big
the balancing weight was. Still, before that it ran fine without being balanced....
blakep82
| posted on 1/4/10 at 04:46 PM |
If u put 2 opposite each other, and the other 2 opposite each other, they 'should' balance each other out.
________________________
speedyxjs
| posted on 1/4/10 at 06:07 PM |
Ok thanks. Iv just put the prop in and the prop is actually too low to put the pickup where i was planning so im going to put the magnets on the
output of the gearbox (as there are some conveniently placed bolts i can use to mount the bracket) so any vibration shouldnt be as bad as if it were
in the middle.
| posted on 1/4/10 at 06:56 PM |
Within an inch of the ends should not affect the balance much, if you can attach them to the yoke it should have no effect at all.
speedyxjs
| posted on 1/4/10 at 07:02 PM |
THat might even be easier! Thanks
jacko
| posted on 1/4/10 at 08:48 PM |
What about on the rear drive shaft or the diff to drive shaft
speedyxjs
| posted on 2/4/10 at 06:03 AM |
Thats what i was going to do originally but the wire is too short and i didnt see the point in extending it when i could just as easily mount it
somewhere else.
