alistairolsen
| posted on 25/5/10 at 12:53 PM |
Anyone got a good guide to stripping an english axle?
I need to pull mine apart to weld on axle mounts and I dont really want to buy a haynes for the only escort component on the whole car
My Build Thread
| posted on 25/5/10 at 01:01 PM |
Easy, 4 bolts at the ends holding the backplates and shafts, remove and pull. Out they pop, weld away and replace
Thinking of new bearings? That's another story, you'll see when you pull the shafts out!
alistairolsen
| posted on 25/5/10 at 01:15 PM |
Found some stuff online, there seem to be two options, either two taper bearings back to back or a cartridge type ball bearing like the front of
modern hatchbacks?
I assume nothing retains the shaft apart from the outer bearing?
My Build Thread
| posted on 25/5/10 at 01:44 PM |
yes but what holds the bearing in place?
There is a collar that is pressed onto the shaft that hold the bearing in place. For peace of mind, peeps will slap 2 blobs of weld, one each side
for balance, to stick the collar to the half shaft.
the only other thing you need for assembly is to know about setting the drive flange bearing preload.
[Edited on 25/5/10 by 02GF74]
dhutch
| posted on 25/5/10 at 07:22 PM |
Friction!!
