Author: Subject: Clonking viscous LSD
phelpsa
posted on 10/9/10 at 07:02 PM Reply With Quote
Was testing the brakes on the driveway the other day and noticed that under tight turns the diff clunks quite alot.
No idea what condition its in or the mileage it's done, all I know is I've just put fresh oil (of the correct grade etc) in it. Anything to worry about?
[Edited on 10-9-10 by phelpsa]
Lars
posted on 10/9/10 at 07:16 PM Reply With Quote
i think mine does the same under right hand bends
would love to know how to fix it
ReMan
posted on 10/9/10 at 08:07 PM Reply With Quote
mine does too when pushing it out of the drive and turning hard.
its normal
Stott
posted on 10/9/10 at 08:17 PM Reply With Quote
Normal, there's no fix. The E30 rally car I co drive in skips the one wheel when turning as it's got a seriously ramp angled diff, I love it, clonk, clonk, clonk, clonk, look at my race/rally car, clonk, clonk clonk
hahahahaha
[Edited on 10/9/10 by Stott]
posted on 10/9/10 at 08:48 PM Reply With Quote
A viscous diff shouldn't really make any noise, but the plate ones can be very noisy.
zetec mike
posted on 10/9/10 at 10:06 PM Reply With Quote
Are you sure its not the Lobro joints ?
phelpsa
posted on 10/9/10 at 10:11 PM Reply With Quote
Nope, but there was no play in them when I fitted them to the car a few months back.
Lars
posted on 11/9/10 at 07:11 AM Reply With Quote
i replaced all mine, its not them.
Mine sounds like the prop hitting the tunnel (but it does not, checked it)
thought my diff is buggered, but if I am not the only one then maybe diff is OK
MakeEverything
posted on 11/9/10 at 07:41 AM Reply With Quote
Its worth checking the bearings in the diff end of the shafts. If the angle is too steep for these, they clonk as they smash themselves through the gaps in the diff.
Kindest Regards,
Richard.
CNHSS1
posted on 13/9/10 at 09:29 AM Reply With Quote
worth whipping the backplate off and having a good look at the sun/planet gears. One of my diffs 'clunked' which very quickly became 'banged' and then 'locked up'!! a stripped sun/planet gear set was the cause (very,very, sticky slicks on hillclimb starts and excessive right foot ;-)
