Author: Subject: Mondeo servo
r1_pete
posted on 15/1/11 at 03:38 PM Reply With Quote
Mondeo servo
Looking for a servo / master cylinder to upgrade my E Types brakes, I noticed the Mondeo servo is on the opposite side to the driver, can someone explain how it is actuated from the pedal?
It might just provide the upgrade I need to get rid of a lot of vintage valves and such junk, which really don't work very well.
[Edited on 15/1/11 by r1_pete]
adithorp
posted on 15/1/11 at 03:46 PM Reply With Quote
Like a lot of tin tops (designed for l/h drive) the pedal operates a long link bar to the lefthand side where a lever operates the brakes.
http://jpsc.org.uk/forum/
austin man
posted on 15/1/11 at 05:15 PM Reply With Quote
if it the same as the mk 3,4,5 escorts theres a beam that goes across the bulkhead whhich actuates the servo and ,master cylinder when the brake is pressed
skodaman
posted on 15/1/11 at 05:18 PM Reply With Quote
The link bar on Mk 3 escorts results in loads of slop and hence a spongey pedal. Mondeo system works fine.
Skodaman
