Author: Subject: suspension problem !!!
nick-york
posted on 23/1/11 at 02:54 PM Reply With Quote
my chassis had all the brackets welded on when i bought it [ from somebody who had bought lots of parts then realised he did nt have enough time to build it !] The problem being when the shock absorbers are fitted there is about half an inch of gap ! is this normal with an easy solution ? The same applies to my two front upper wishbones ! The lower ones fit perfectly !I really don t want to have the hassle of putting new brackets on if it can be helped . so any iva friendly solutions would be greatly appreciated .
bob
posted on 23/1/11 at 03:09 PM Reply With Quote
1/2" of gap where ?
Have you any pictures ?
Flamez
posted on 23/1/11 at 03:19 PM Reply With Quote
Are you using Rose joints if so spacers will be required, at a pinch use washers whilst setting up the geometry.
my build mac1motorsports
nick-york
posted on 23/1/11 at 03:22 PM Reply With Quote
I could take pictures but it would probably take me quite a while to get them on but i ll try . When the shock absorbers or front wishbone are mounted in their brackets there is about a quarter of an inch gap on either side . As if the inside measurement of the brackets was half an inch too wide . Its like they need spacers on either side or something else .
snapper
posted on 23/1/11 at 03:27 PM Reply With Quote
Poly bushes have 1/4" either side, if this is still not wide enough spacers would be ok
I eat to survive
I drink to forget
bob
posted on 23/1/11 at 03:28 PM Reply With Quote
As said above spacers, washers will do to set up in fact i've left my washers in and 7 years on they are fine.
nick-york
posted on 23/1/11 at 03:31 PM Reply With Quote
No not using rose joints .metalastic i think they re called .So what would be the iva friendly solution in the long term please ?
posted on 23/1/11 at 03:33 PM Reply With Quote
Use stainless steel washers to pack out the shock absorber and the wishbones in fact use them as adjustment for your castor on the wishbones
PSpirine
posted on 23/1/11 at 03:34 PM Reply With Quote
To summarise - nothing to worry about once you've used some washers!
nick-york
posted on 24/1/11 at 10:44 PM Reply With Quote
Thanks everyone . stainless steel washers it is. cheers !
Uphill Racer
posted on 25/1/11 at 12:36 AM Reply With Quote
Nick, do you understand what Rusty said?
The gap on the wishbone is intentional, it allows lateral movement to set the castor angle.
nick-york
posted on 27/1/11 at 10:14 PM Reply With Quote
I thought i understood what rusty said but when i read this i realised i was getting a bit confused about it all !learning s lots every day ! Cheers !
